How do i measure time in code? I want to use SR04 distance sensor.
Volvo742
2016-06-08
2016-06-10
  • Volvo742 - 2016-06-08
    Hello!
    I wonder how i can measure time in code. For example.
    time1 := clock time;
    Operation..... or some stuff
    time2 := stop clock;
    time := time2 - time1
    If that is possible, i can use the digital SR04 distance sensor.
    Here is the data sheet about the sensor. Look at the timing diagram.
    http://www.micropik.com/PDF/HCSR04.pdf m
  • frankienones - 2016-06-09
    Maybe like this ?
    [url][/url]
    Here the result is in time() format
    Frank
    IMG: Function_Block.png
    FB.txt [851 Bytes]
  • Volvo742 - 2016-06-10
    frankienones hat geschrieben:
    Maybe like this ?
    Function_Block.png[url][/url]
    Frank
    Thank you. I will test it later today and give you a reply.
    Edit: it working.
