I try to use the "DATE and TIME PICKER" visualization element.
When i use it with your example works OK.
When i try to insert it in my project that have updated from old version "3.5.8.0" i take the follow errors:
Any help?
Regards
Is there any ready VisuDialog for edit Time variables like TOD,TIME,DATE,DATETIME ?
Regards
use attached example.
DateandTimePickerVisuSP9.project [64.07 KiB]
Hi Edwin
Any help?
Regards
you need to CODESYS 3.5.9.x -
if you are still working with it use current Compiler Version 3.5.9.x and Visuprofile 3.5.9.x
I use Compiler Version 3.5.9.1 and Visuprofile 3.5.9.1 but the problem exists.
Regards
is it possible to add your project or parts of it to check.
Here we are...
Regards
Test_Time.zip [556.05 KiB]
hi,
this is a bug, the only workaround is to deactivate the property handling for the visualisation.
Hope you could work without.
