Run communication after reboot
suibaf
2016-02-13
2016-02-18
  • suibaf - 2016-02-13
    EtherNet/IP communication tra Raspberry PI2(scanner) and a PLC work fine as you can see:
    But if I reboot the raspberry the communication does not work.
    To start the communication it need a hot reset or a cold reset.
    How is it possible to run the communication itself after a reboot?
    Thank you
    IMG: Bild
    IMG: Bild
  • suibaf - 2016-02-14
    If someone want to look the project, you can download it from following link.
    https://dl.dropboxusercontent.com/u/152 ... ectarchive
    The project work fine, but if reboot the raspberry, the ethernet/IP communication does not work.
    Currently for start up communication after reboot I have to perform a hot or cold reset.
  • suibaf - 2016-02-15
    Maybe I understand the problem, but I have no solution. Please look the screenshot! Have you advice for me?
    IMG: Bild
    eschwellinger - 2016-02-15
    guess we could provide you with an solution tomorrow.... some additional tests are needed.
    eschwellinger - 2016-02-16
    we need more time ... sorry for this.
  • suibaf - 2016-02-16
    No Problem Edwin! I wait!
    Do you think that it is a bug?
    eschwellinger - 2016-02-18
    yes it is a bug and it need to be solved in CODESYS
    The workaround is to use a static assigned IP till the fix is released.
  • suibaf - 2016-02-18
    Hi Edwin,
    Raspberry has already a static assigned IP.
    IMG: Bild
    OK now it work fine:
    IMG: Bild
