Hello
My raspberry get an IP address by a DHCP server. I want to show it on a visualisation page.
What function block and what library should J use to find the IP address by programme......
Thank you in advance for your reply
use SysSocket lib following codesnippet or check attached Project example
PROGRAMPLC_PRGVAR  sHostName  :STRING;  Host:SysSocket.SOCK_HOSTENT;  pIPAddress :POINTERTODWORD;  in_addr   :INADDR;  sIPAddress :STRING:='aaa.bbb.ccc.ddd';  sTextEingabe:String;END_VAR(*Getownhostname.*)SysSockGetHostName(szHostName:=sHostName,diNameLen:=SIZEOF(sHostName));(*GetownIPaddressbyitsname.*)SysSockGetHostByName(szHostName:=sHostName,pHost:=ADR(Host));pIPAddress:=Host.pAddrList[0];//selecttheadapterofaddrList[]in_addr.ulAddr:=pIPAddress^;SysSockInetNtoa(pInAddr:=ADR(in_addr),szIPADDR:=sIPAddress,diIPAddrSize:=SIZEOF(sIPAddress));
yes even this is possible:
You need to ad 'CmpSysEthernet' to the LibraryManager
then then the following code snippet should help.
getnumberofadapters(ADR(diNumber));FORiAdapter:=0TOdiNumberDOPROGRAMPLC_PRGVAR  diNumber:DINT;  iAdapter:DINT;  stName:STRING(255);  stDescription:STRING(255);  aby_address:ARRAY[1..6]OFBYTE;END_VAR  getadapterinfo(  iAdapterNum:=iAdapter,  pbName:=ADR(stName),  pbDescrition:=ADR(stDescription),  iBuffersize:=SIZEOF(stName),  iMacLength:=6,  sMacAdress:=ADR(aby_address));END_FOR
Hello
Hi Jabib,
PiFaceIoDrv_LadderExample_andSysProcess.project [104.28 KiB]
And is this the same way for wlan0 address ?
Host.pAddrList[0] returns the eth0 address but wlan0 is another adapter of addrList[], no ?
Hi Edwin,
Thank you. Its work well.
How to discover the possibilitése all those libraries that are not documented in the online help ?
It lacks a Wikipedia section !
great,
and the mac adress?
thx
Thank You,
work perfect.
Thank you very much
Great!
Is there possible to get a Serial number from CPU?
Thank You!
Best regards,
Zdenko.
Great info! So is there a way to combine these two and get the IP address from eth0 always? Thanks
