Var declaration AT %MW...voiding memory overlapping
hki75
2015-10-22
2023-08-17
  • hki75 - 2015-10-22
    I need to declare some variable mapped to %M address, something like:
    Timer1 AT %MW0 : TON;
    The question is: how to know the right offset for each variable to void memory overlapping?
    ex:
    Timer2 AT %MW ?? : TON;
  • Jonascox - 2015-10-27
    hki75, unlike Siemens, you don't need to offset your variables of like kind.
    Timer2 AT %MW1 : TON;
    Word3 AT %MW2 : word;
    However, if you use Bytes as a starting point, you can overlap memory. Like this:
    Word1 AT %MB0 : Word;
    Word2 AT %MB2 : Word;
    Word3 AT %MB3 : word; ( This variable will be overwritten by the variable starting at %MB2 )
  • hki75 - 2015-10-27
    Hi Jonascox,
    thanks for reply.
    I try to insert your suggestion into Codesys but it doesn't work..for the following reasons:
    TON (timer cannot to be defined AT odd address %W:
    ex:
    Timer1 AT %MW1 : TON; --> return error compiler 3729
    Defining
    Timer2 AT %MW2 : TON;
    --> compiler return:
    the only way I found to void memory overlapping during compiling is this:
    Timer1 AT %MD0:TON;
    Timer2 AT %MD6:TON;
    (it seems each timer needs 6 dword memory allocation)
    But my question was: how to know it in advance without try with different data type (MB or MW or MD...) and compiling every time until I get
    IMG: Bild
    IMG: Bild
    hki75 hat geschrieben:
    Hi Jonascox,
    thanks for reply.
    ex:
    Defining
    Timer1 AT :TON;
    Timer2 AT :TON;
    Is there a reason you need the TON's defined at an absolute memory location?
    It is much simpler to define them without an absolute address.
    Example:
    Timer3:TON;
    The timer bits can be used in your code directly. They are predefined and shouldn't be added to any variable list.
    Example:
    Timer3.Q (Done Bit)
    Timer3.ET (
    Elapsed Time)
    Timer3.PT (
    Preset Time*)
    Etc.
    IMG: Bild
    IMG: Bild
  • hki75 - 2015-10-28
    I know it's easier to define FB without physical memory addressing, but I need it..
  • Jonascox - 2015-10-28
    I found that each timer uses 4 DINT's.
    So I would put the timer names in a spreadsheet and add the %md** in the column next to them. Fill out the first 2 or 3 names and addresses then drag the cells down to have the spreadsheet auto-fill the rest of the memory names. In this way you can determine where each timer memory starting point will fall.
