hi everybody
i create a program by codesys i want to simulate this...
first how can i do ?
second : i go to online > simulation then online > logit...
now i want change variable but i do't understand how..?!?
i write this program by scl language
thank...
naeimi
yes you put a check on simulation
then you go online
now you can change and check all variables used in program:
double click on any variable and a popup will appear to change it. (a bool will change status
then run the program. name your program PLC_PRG (yes i know about tasks but to early to ngin on this.)
first program in ST:
output1:=input1;
it will ask for type use bool (standard so just hit enter)
run the program and doubleclick on input1
hi everybody
thank...
naeimi
What is SCL?
then you go online
output1:=input1;
