When jumping between text fields using the arrow keys the entire field becomes highlighted. To change only a portion of text, you have to then double click the mouse to drop the selection and just get cursor in edit mode.
This is very irritating as it is much faster to only working with keyboard.
Is there any way to get the cursor inside the text field for editing without mark the whole text? In other system its usually F2, SPACE or ENTER.
Regards
Johan
yes there is use home key and end key
home gets you to the start of the variable and end gets you to ...... the end
F2 is used to open an assist to variable and functions etc.
and Enter gets you to the next one
Regards
Johan
SOLVED
Thanks, this will make may day.
