I came across strange issue. I have some variable of type PERSISTENT RETAIN and when I switch declaration view from text to table form, PERSISTANT is getting stripped out and moved into VAR section like variable NAME. So, when I covert back to text format, declaration of PERSISTENT RETAIN variables changes to RETAIN and PERSISTENT becomes its own varible. Here is an exampe.
I start with
VAR PERSISTENT RETAIN
testPersistantVar:BOOL:=TRUE;
END_VAR
Then I go to table format and back to text, the declaration changes to
Hello everyone
I start with
END_VAR
VAR RETAIN
END_VAR
Is this a bug in CoDeSys? Is there a way to create varibale PERSISTENT RETAIN in table format?
I am using CoDeSys version 2.3.5.8
Thanks
