copy online parameters to offline parameters
2017-01-31
2017-05-31
  • Anonymous - 2017-01-31
    Originally created by: KevinR
    Dear Community,
    can I copy all online parameters to the offline parameters with a python script?
    This will give me the opportunity to save the current online configuration values to my offline project file.
    Visual concept:
    Thank you in advance
    Regards,
    Kevin
    IMG: Python.png
  • mkeller - 2017-02-01
    Hi Kevin.
    KevinR hat geschrieben:
    A device parameter or data element in Scripting has the property "can_access_online" so you can check if it supports the online mode. If it is supported you can read the current value with the method "read_online_value(...)". If a timeout of 1000ms is enough to read the value from the PLC you can use the method without specifing that parameter.
    Here some untested code:
    if data.can_access_online:
    Β  Β val = data.read_online_value()
    Β  Β data.value = val
    I also added a simple python script which prints the parameter tree to the Message view and change the value of one parameter.
    Martin
    device_show_and_change_parameters.py [1.65 KiB]
  • Anonymous - 2017-03-01
    Originally created by: Steffen_R.
    Hi Martin,
    i tried running the script but it does not work correctly. The attached picture shows the error. I think it is line 15 in the script.
    Thank you
    Steffen
    IMG: Fehler.PNG
  • Anonymous - 2017-03-02
    Perfect!!
    Thank you very much... That helps me
    Steffen
  • Anonymous - 2017-05-31
    Hi Martin,
    I'm still looking for a solution, to get this to work.
    First of all - Thank you for updating the example. The example still doesn't work for me, during I'm in the online mode.
    I stay in contact with one of your colleague, who has also added the issue to jira (CDS-54028).
    It seems like there is a problem with "read_online_value".
    This functionality has a very high importance for us. So maybe there are also some other customers who have this requirement.
    Thank you in advance.
    KevinR
