I would like to set up an automated software build system on a scripting base.
Therefore I start a batch file containing the "codesys --runscript" commands for a python script to compile a codesys project with the option --enablescripttracing.
This works fine, but the trace output is not redirected into a file completely.
On cmd prompt the batch file output ist redirected via "build.bat >> log1.dat" - ok
Within build.bat the python "print()" script commands are redirected via "> log2.dat Codesys --runscript ..." - ok
But the codesys compiler messages are displayed within cmd prompt
How can I redirect the messages that come out of codesys during e.g. the python command "app.create_boot_application(bootapppath)" ?
Best regards
Dirk
DBe hat geschrieben:
Here some example code:
CompileCategory=Guid("{97F48D64-A2A3-4856-B640-75C046E37EA9}")found=projects.primary.find("Application", True)app=found[0]
\# ClearmessagesfromBuildcategorysystem.clear_messages(CompileCategory)app.create_boot_application(r"C:\Temp\App.app")
\# Getmessageobjectswhichcontainallthedataseverities= {
  Severity.FatalError : "Fatal error", Severity.Error : "Error",
  Severity.Warning : "Warning", Severity.Information : "Information",
  Severity.Text : "Text"
msgs=system.get_message_objects(CompileCategory)formsginmsgs:
  sev=severities[msg.severity]
  print("{} {}{}: {}".format(sev, msg.prefix, msg.number, msg.text))
\# Or: Getonlythemessagetextmsgs=system.get_messages(CompileCategory)formsginmsgs:
  print(msg)
Martin
thank you very much! The compile information is printed within cmd prompt AND log file now .
During project creation I do a SVN checkout (via codesys addon). These reports are printed within cmd prompt only.
Is there another GUID available for this too?
Dirk
Use the following code to get a list of all available message categories:
guids=system.get_message_categories(False)forguidinguids:
  print("GUID: {} Description: {}".format(guid, system.get_message_category_description(guid)))
If you replace "False" with "True" in "get_message_categories()" you only get the active message categories.
Martin
SkriptMeldungen:Information:Build.py(23):Ausnahmefehler(<type'exceptions.AttributeError'>,AttributeError(u'F\xfcr dieses Objekt wurde kein parameterloser Konstruktor definiert.',),<tracebackobjectat0x000000000000002B>)SkriptMeldungen:Information:Build.py(23):    print("GUID: {} Description:{}".format(guid,system.get_message_category_description(guid)))SkriptMeldungen:Information:Build.py(23):Ausnahmefehler(<type'exceptions.AttributeError'>,AttributeError(u'F\xfcr dieses Objekt wurde kein parameterloser Konstruktor definiert.',),<tracebackobjectat0x000000000000002C>)
Kind regards
Dirk
Best regards
Dirk
Hi DBe.
Martin
Hi Martin,
Dirk
Hi DBe.
Martin
Hi Martin,
works fine - thank you!
Only one small remark:
"HMI Meldungen" has no constructor? Therefore you algo fails.
But a try-catch filters this.
Dirk
Hi DBe.
Which version of CODESYS do you use when this error happened?
Martin
Hi Martin,
I use Codesys 3.5 SP5 Patch 7 with a build profile 3.5 SP3.
Using these commands:
I get these errors:
Kind regards
Dirk
Hi Dirk.
The problem is not the HMI category. It's only the last working category before the error.
I tried it with two newer versions. With CODESYS V3.5 SP6 the problem still exists. With CODESYS V3.5 SP7 there is no error.
Martin
