Error - object reference not set to an instance of a object
sg
2016-06-03
2016-06-13
  • sg - 2016-06-03
    On one of our computers, when writing values to variables through a script. We get the above mentioned exception. I see that it does write all the prepared values, but after that it throws the exception. All this happens in the function online_app.set_prepared_value
  • Anonymous - 2016-06-08
    If the issue is reproducible on your side, could you try to get a stack trace? This can be done via python, or (simpler) using the DiagnosisToolLauncher.exe in the CODESYS Common directory.#
    Thank you.
  • sg - 2016-06-13
    The log file is attached. One is before clicking ok on the exception dialog and the other is after
    codesys_log.zip [31.54 KiB]
