Set device to simulation mode
sg
2016-02-05
2016-02-08
  • sg - 2016-02-05
    I cant find a way to set the device, which my active application belongs to, in simulation mode. How do I get the reference to the interface IScriptDeviceObject for it.
    Any help is appreciated.
  • mkeller - 2016-02-08
    Hi Shabroz.Gill.
    Shabroz.Gill hat geschrieben:
    Search for the device object by using find() and use the method set_simulation_mode() for setting the simulation mode.
    For example:
    proj = projects.primary
    found = proj.find("Device", True)
    assert(len(found) == 1, "No or too many devices with the name 'Device' found")
    dev = found[0]
    dev.set_simulation_mode(True)
    assert(dev.get_simulation_mode() == True, "Simulation not active")
    Martin
