Hey, is there a way to use the " copy (branch/tag) " command ... and some steps following (switch to new location, increment version numbers, Placeholders...) within python (CODESYS). Thanks!
thanks, works fine. One thing. How to switch to the new location? I tried sharpsvn and i tried script interface. What is the best way? I am a little bit confused... path, uri, string, SvnUriTarget...
Hi.
The branch/tag commands were simply forgotten for the script interface. We have already an entry in our bugtracking. See SVN-162.
There are two workaronds:
Use the following command where the second parameter (as boolean) specifies if you want to switch to the new branch:
Use the SharpSVN library directly (see attached python file)
Martin
testbranch.py [417 Bytes]
Hi MaGu.
If you use the Copy command you can change the second parameter to "true" for switching immediately after the copy:
Otherwise you can use one of the switch methods of the project object. Look for IVersionedProject in the scripting documenation.
Martin
