The project created by the script contains the "LibraryManager", but not the standard POU 'PLC_PRG' and not the 'Taskkonfiguration'.
Where have I made a mistake?
CoDeSys V3.4 SP3 Hotfix 1
I have just tried out with CoDeSys V3.4 SP3 Patch 2 ==> It works
Was is a bug in CoDeSys V3.4 SP3 Hotfix 1?
I only changed the device version (3.4.3.0 ==>3.4.3.20):```
I am not 100% sure, but I believe it is related to the device description file of the PLC.
If you haven't un-installed the previous version, you could choose the new device description in this older version and run the script again.
jbo hat geschrieben:
I only changed the device version (3.4.3.0 ==>3.4.3.20):\# add PLC
proj.add("LMC_PacDrive",4096,"0000 0001","3.4.3.20
Sorry, that was a mistake.
It does not work
Actually that is the normal behaviour, because you start a new empty project and then add the Device.
With the (manual) CoDeSys File New "Wizard" you can choose a standard project which let you select the Device and POU language. Only then it will add the Task and PLC_PRG automatically.
With the script I think the only solution is to add this yourself.
Anonymous
2015-10-21
Originally created by: Maximilian.Blase
is it possible to insert a new POU by Python script?
Best regards,
jbo
Hi @ all,
over four years have passed since the last entry. Therefore i wannted to ask again, if it is now possible to create a new POU or DTU with Python without xml im- and export.
Best regards,
M. Blase
Maximilian.Blase hat geschrieben:
Hi @ all,
Right now, this is not yet possible, but this improvement is already listed in our Jira tracker CDS-44087 , so it will be implemented eventually.
Since CODESYS V3.5 SP6 you can read and write the textual declaration and/or implementation part of POU objects which have one. Search for "IScriptTextDocument" and "IScriptTextualObjectMarker" in the ScriptEngine documentation.
Martin
Anonymous
2015-10-21
Hi Martin,
let me first say thank you for your very quick response. Less than 30 minutes. I am impressed. Also it is a little bit funny because we are both from germany. Who cares.
M.Keller hat geschrieben:
I've already read about this possibility and so this was my intention at the second step. But at first i have to create new POUs and DTUs, or? Otherwise the objects have to be generated in the past manualy. This is the point i want to avoid.
Best regards,
Maximilian
Anonymous
2015-10-22
Yes, they have to be created - but for creating them, you could always use the same PLCOpenXML template of an empty POU, which you could even embed as a string into your Python script. Then use rename and text editing functions to populate it.
HTH,
Markus
M.Schaber hat geschrieben:
HTH,
Markus
Is it possible that only POUs from type Function_Block can be edited with the IScriptTextDocument Methods.
Because a POU of type Program returns at request for has_textual_declaration and has_textual_implementation both with false (3.5 SP7), while returning true for type of Function_Block.
Anonymous
2016-02-29
PLKM hat geschrieben:
In my test, it works with SP7.
One common mistake is that your script might work on the Task Call object below the Task configuration which is calling your PROGRAM - it has the same name as the PROGRAM it calls, and thus the script might accidentally find it, instead of the PROGRAM itself.
If that is not your problem, please send a stripped-down example project and script to e support@codesys.com e , so we can reproduce and fix the problem.
My fault. As you said i had chosen the PLC_PRG task instead of the PROGRAM itself.
Best regards,
jbo
If you have already created it and exported it to .xml (manually), you can import it with a script.
See my post about import XML.
Hi, Jbo,
As TimvH wrote, it is possible to insert a POU via PLCOpenXML import (and in 3.4 SP4 also in the normal standard export format).
PLCOpenXML can be imported from a file and from a string, that means that you can even "embed" the POU XML as a multiline string in your script.
Markus
Hi TimvH, Hi M.Schaber,
many thanks for your answers.
Background of my question:
I created a new project by the following Python-Script:
# add PLC
It does not work
Hi @ all,
Best regards,
M. Blase
Hi M. Blase.
Martin
Hi Martin,
Best regards,
Maximilian
HTH,
Markus
