Error handling while reading Modbus TCP
meuzumcu
2017-06-09
2017-06-13
  • meuzumcu - 2017-06-09
    Hi..
    In my project I want to read registers from a modbus tcp slave device. In normal conditions everything is ok but I must handle an error bit while an reading or socket error at communication.
    For example when turn off the power of slave device, a communication error occurs. So how can understand the error of modbus tcp.
    Thanks already..
    IMG: Bild
  • teichhei - 2017-06-11
    If you have control over the slaves you could toggle a bit and increase a counter on the slave side and read that back, make sure it increases. But if there is a way to access the on board diagnostics from Codesys that would be nice.
  • TimvH
    TimvH - 2017-06-13
    Each modbus slave device has a property "byModbusError".
    In your case you can use e.g. the following code:
    Mb1State := Modbus_TCP_Slave.byModbusError;
    Mb1State is then of the following type:
    Β  Β Mb1State: IoDrvModbusTCP.MB_ErrorCodes;
    In the library "IoDrvModbusTCP" you can find this ENUM (in the Structs folder) to see the details.
