I am using Codesys in Schneider's Electric Somachine V4.1SP2. I want to create a Auto Tuning 3 State P.I.D. process. The three states of the PID would be Null, Up, Down so i could control a three way valve. As i have seen and used before, vendors like Siemens has a so called 3-Step P.I.D. i would like to know if Codesys has a workaround for this process.
Thank you in advance
Originally created by: Viacheslav Mezentsev
As I know you must do it yourself.
One example (rus): link.
maybe you could check the oscat libraries...
https://store.codesys.com/catalogsearch/result/?q=OSCAT
Hello again,
I will check these and come back later
Thanks a lot for your afort
