Hitachi PLC HX-CP1H16 login
himanshu
2017-03-16
2017-03-21
  • himanshu - 2017-03-16
    Hi..
    I have created project and downloaded to Hitachi HX Cp1h16 PLC.
    Its running and I have logged into it.
    Now my question is that I want to access CPU from another PC for monitoring purpose using same project.
    Now if I login from another PC then it does not allow.
    How to do this ?
  • Joan M - 2017-03-16
    If you can connect to the PLC from the computer 1, then it looks like that the problem resides on the computer 2...
    Firewall issue? (given you are using Ethernet)
    Bad Ethernet port? (given you are using Ethernet)
    Software not installed correctly?
    Just to clarify any doubt about it, you can't log in at the same time from two computers.
    Does any of those assumptions help you?
  • himanshu - 2017-03-21
    Hi.. Thanks for reply
    I can go online from either computer. There is no issue.
    My question was that I want to login from Both Computer .
    Computer 1 will have project and login. Computer 2 will access the project path of computer 1 and try to go online and login.
    Basically requirement is In computer 1 , I want to open some POU's and in computer 2 I want to open rest POU's.
    Is it possible ?
  • Joan M - 2017-03-21
    Not possible as far as I know...
    ok
