I'm making a trace function block meant to be used with our HMI.
Amongst other things, I need to pass a trigger variable and what to trace.
The problem is that these variables could be of any base type, unknown to me at design time.
From my understanding, I can only declare a pointer to a specific base type.
I could ofc make a struct with one pointer of each base type and then have another variable stating what type is used, but surely there must be a better way of doing this?
How can I solve this in a nice way?
Create a union of the various pointer types instead of a structure. You may also want to consider using REFERENCE instead of POINTER; it may or may not be easier to use dending on your specific usage.
