I use Codesys V3.5 SP8 Patch 2.
With trace recorder I write a file in .csv with the values of two variables and then use it in Excel.
Field Trigger.Date writes the date/time in a format that I cannot turn with Excel.
For example, today Trigger.Data; 147557616 This number should indicate today date and time (04/10/2016).
How can I decode this number?
Thanks to all.
Domingo hat geschrieben:
For example, today This number should indicate today date and time (04/10/2016).
It must be Unix date (and time) format, but I think you are missing a zero?
147557616 gives: "Wed, 04 Sep 1974 20:13:36 GMT"
1475576160 gives: "Tue, 04 Oct 2016 10:16:00 GMT"
So in excel you have your unix date (date and time stamp it is) in cell A1 and in an other cell (that you format as date) type: =A1/(606024)+"1/1/1970"
Thanks to all.
