hi all,
can any one help me on this .
i want to Display files in specific path on the visu. other side USB Folder data.
i want to acesss file and del or copy to usb or usvb to sys ..
can any one give some idea .
please also see the below example , how i want to do on visu
maybe you would like to have a look at the VisuDialog example in Store.
good luck.
2016-10-04
Originally created by: barkamharikrishna
Hi learnetk,
thanks for the info.
i had downloaded and installed VisuDialog example in Store.
can you please tell me how use it , where i can find it in lib or some other place .
hi all,
good luck.
Hi learnetk,
Once the package has been installed, the example program can be found under your User directory
\CODESYS Examples\Visu Dialog ST\1.0.0.2\
There are a few application in the example Project, but maybe 'FileDialog' could be one you are looking for.
Good luck.
