SysFileOpenAsync
2014-01-20
2017-03-15
  • Lohr-DCIA-EHE1 - 2014-01-20
    When I run the following program, I get in ResultAsync the error 2.
    That means invalid parameter for this operation.
    What can be the cause of this ?
    // DECLARATION:
    PROGRAM Test
    udStateOpen: UDINT := 16#FFFFFFFF;
    TestFB : SysFileAsyncFB;
    SFO : tSysFileOpen;
    TestString: STRING;
    TestAccessMode: UDINT;
    Result, ResultAsync, OUT, hJob: UDINT;
    // IMPLEMENTATION:
    SFO.szFile := TestString;
    SFO.am := TestAccessMode;
    SFO.pResult := ADR(Result);
    SFO.pulOut := ADR(OUT);
    hJob := TestFB.SysFileOpenAsync(ADR(SFO), ADR(udStateOpen), ADR(ResultAsync));
  • Anonymous - 2017-02-13
    Originally created by: Viacheslav Mezentsev
    Up.
    The same question. Is there a complete example of using asynchronous (non blocking) read? I need to read input event ('/dev/input/event1').
    CoDeSys 3.5.10.x.
  • Anonymous - 2017-03-15
    Worked example.
    PROGRAM PLC_PRG
    var constant
       STATE_IDLE:    byte := 0;
       STATE_CONFIG:    byte := 1;
       STATE_OPEN:    byte := 2;
       STATE_FLUSH:    byte := 3;
       STATE_READ:    byte := 4;
       STATE_READWAIT: byte := 5;
       STATE_CATCHEVENT: byte := 6;
       STATE_CLOSE:    byte := 7;
       STATE_CLOSEWAIT: byte := 8;
    end_var
    var
       ready: bool;
       step: byte := 1;
       state: udint;
       result: RTS_IEC_RESULT;
       file : SysFileAsync.SysFileAsyncFB;
       jobparams : SysFileAsync.AsyncJob_Param;
       taskName : string := 'EventTask';
       open : SysFileAsync.tSysFileOpen;
       write: SysFileAsync.tSysFileWrite;
       read: SysFileAsync.tSysFileRead;
       close : SysFileAsync.tSysFileClose;
       ulOut : SysFileAsync.RTS_IEC_RESULT;
       fileName: string := '/dev/input/event1';
       event: array [0 .. 15 ] of byte;
    end_var
    case step of
       STATE_CONFIG:
          jobparams.TaskParam.pszTaskname    := adr( taskName );
          jobparams.TaskParam.ulTaskPriority    := SysFileAsync.TASK_PRIORITIES.TASKPRIO_IDLE;
          jobparams.TaskParam.ulTaskSleepTime := 10;
          jobparams.TaskParam.phTaskHandle    := SysFileAsync.RTS_INVALID_HANDLE;
          jobparams.TaskParam.ulEndTaskAfterJob := 0;
          file.AsyncSetJobParams( SysFileAsync.ASYNCJOB_TASK, 1000000, adr( jobparams ) );
          step := STATE_OPEN;
       STATE_OPEN:
          open.szFile := fileName;
          open.am := SysFileAsync.ACCESS_MODE.AM_READ;
          open.pulOut := adr( ulOut );
          file.SysFileOpenAsync( adr( open ), adr( state ), adr( result ) );
          step := STATE_READ;
       STATE_READ:
          if state = SysFileAsync.ASYNCSTATE_READY or state = SysFileAsync.ASYNCSTATE_ERROR or state = SysFileAsync.ASYNCSTATE_TIMEOUT then
             (* The file is correctly opened *)
             read.pbyBuffer := adr( event );
             read.ulSize   := sizeof( event );
             read.pResult   := adr( result);
             read.pulOut    := adr( ulOut );
             State := 0;
             file.SysFileReadAsync( adr( read ), adr( state ), adr( result ) );
             step := STATE_READWAIT;
          end_if
       STATE_READWAIT:
          ready := state = SysFileAsync.ASYNCSTATE_READY or state = SysFileAsync.ASYNCSTATE_ERROR or State = SysFileAsync.ASYNCSTATE_TIMEOUT;
          step :=   sel( ready, STATE_READWAIT, STATE_CATCHEVENT );
       STATE_CATCHEVENT:
          step := STATE_READ;
       STATE_CLOSE:
          close.pulOut := adr(ulOut);
          file.SysFileCloseAsync( adr( close ), adr( state ), adr( result ) );
          step := STATE_CLOSEWAIT;
       STATE_CLOSEWAIT:
          (* The file is correctly closed *)
          step :=   sel( ready, STATE_CLOSEWAIT, STATE_IDLE );
       STATE_IDLE:   ;
    end_case
