It is currently Sat Mar 25, 2017 10:36 am
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Retain Variables
PostPosted: Tue Jul 02, 2013 11:28 pm
I need to save setting that are entered in Wachendorff Opus A1 RVC display and would like to use Retain Variable Flag. I have set the flag for the Variables that I want to save after power off, for Retain and Persistant. But it does not work. I have not found any good documentation on using Retained variables. Can anyone lead in me in the right direction on what I need to do in order to use RETAIN variables and save the settings that are made. Any thoughts would be appreciated. Thanks
Scott
 Post subject: Re: Retain Variables
PostPosted: Wed Jul 03, 2013 11:20 am
It depends on whether the PLC has a battery backed up memory and if the battery is OK.
With the CODESYS Control RTE on PC based systems many tiimes there is no battery backup possible. In that case it is possible to save the retain data to a file and restore it after starting up again. Maybe that also works in your case.
You could try the following:
1)
Add the following libraries to your project:
- Standard.library
- CmpApp.library
2)
Use the following code. In this case you have to manually set the xSave bit to TRUE to save it (could be a SAVE button which you create in your visualisation).
Then do a warm reset and start the PLC again. Then you can test if the counter value is restored.
PROGRAM PLC_PRG
   xStartUp : BOOL := TRUE;
   xSaveRetain: BOOL;
   pApplication : POINTER TO CmpApp.APPLICATION;
   diMyResult : DINT;
   ton1 : TON;
VAR RETAIN
   iCounter: INT;
IF xStartUp THEN
   pApplication := CmpApp.AppFindApplicationByName('Application', ADR(diMyResult));
   CmpApp.AppRestoreRetainsFromFile(pApplication, 'C:\MyRetainData.ret');
   xStartUp := FALSE;
ton1(IN:= NOT(ton1.Q), PT:= T#2S, Q=> , ET=> );
IF ton1.Q THEN
   iCounter := iCounter + 1;
IF xSaveRetain THEN
   AppStoreRetainsInFile(pApplication, 'C:\MyRetainData.ret');
   xSaveRetain := FALSE;
PostPosted: Thu Jul 11, 2013 2:16 pm
TimvH, Thanks for the information an I think I almost got it, but it is not working yet. I have added the code example you posted to my program and as soon as I download the program to the device I get an Exception error, "Exception Detected see _._". I am not sure why but in the original sample code you posted you have a variable "diMyResult" and was wondering what that variable needs to be set too. I posted the code I wrote below hoping you see a problem. Also, do you know where I can find any documentation on the CmpApp Library that goes into some detail on how the functions work. I can't find anything that was helpful. Thanks again. ScottJones
     pResult : RTS_IEC_RESULT ;
   retname : STRING;
   pApp : POINTER TO CmpApp.APPLICATION;]
pApp := cmpapp.AppGetCurrent (ADR(pResult));
retname := concat (pApp^.szName, '.ret');
IF firststart THEN
   Heartbeat := ADR(CANStack^.m_uiHeartBeatTime); // Initialize the CAN Network Heartbeat
   Heartbeat^ := 2000;
   // Restore Retained Values
   pApp := CmpApp.AppFindApplicationByName ('Application', ADR(pResult));
   CmpApp.AppRestoreRetainsFromFile (pApp, retname );
   firststart := FALSE;
IF SaveRetain THEN
   pResult:= AppStoreRetainsInFile (pApp, retname );
PostPosted: Fri Jul 12, 2013 12:31 pm
It is probably related to the target that you get an exception, because I don't see any wrong coding.
Maybe you can set a breakpoint in the first line and step through the application to see when the exception occurs.
The "call stack" (menu: View) maybe also gives you an idea where the program was halted.
A reason could be that you haven't specified the correct filepath + name.
Can you write files to your controller, if yes, how do you specify the filename?
PostPosted: Sun Jul 14, 2013 11:52 pm
Tim, Thank you for the help. I was able to get it working. I had originally had the variables initialized when they were declared, but deleted the initialization values when I started working on getting the Retain Variables to save to a file. When I did that, I created a division by zero error that I did not see right away. Also, I am not sure this is specific to Wachendorff displays but I did not need to use the Restore Retain function. Retains are restored automatically when the display is powered up. Again, thanks for you help it really helped me figure my problem out. Scott Jones
PostPosted: Sun Nov 15, 2015 3:58 pm
I would like to do the same thing with raspberry pi, but I don't undestand where I have to put this code and which language is it.
Could you post a project example ?
Thank you very much.
PostPosted: Sun Nov 15, 2015 4:12 pm
First of all check if your device already supports retain variables (battery backed-up memory).
If this is the case, you don't need to add any code to your application (like above) and it is done automatically.
If it doesn't support it, you can use the code in the earlier posts and paste it in a "structured text" POU to check if it is working on your device.
PS, there are also alternative ways to store your variables in a file.
See the help of CODESYS for "Data Persistence". The "application composer" "persistence manager" could be a better solution.
PostPosted: Sun Nov 15, 2015 4:16 pm
Thank you for your answer. Auto record of persistent data work only with proper shutdown. With my Rpi, nothing work: persistent are reset to 0 with normaly shutdown.
I continu to search.
PostPosted: Sun Nov 22, 2015 4:22 pm
On raspberry pi and codesys, where I have to record files ? /home/pi/MyRetainData.ret ?
I have pt the same code on raspberry, cmpApp library, but it doesn't work. Problem of address files ? access ?
PostPosted: Sun Nov 22, 2015 7:17 pm
should work on Raspi too.
You'll find the file in /root/
PostPosted: Sun Nov 22, 2015 7:50 pm
Ok, solution in files.
