Windows 7 - 64Bit
farrowz
2010-12-07
2016-12-05
  • farrowz - 2010-12-07
    Has anyone had success with running version 3 on a 64bit windows 7 platform? If so, how did you get it to work?
  • TimvH
    TimvH - 2010-12-07
    This is not supported yet, but it works perfect in the Virtual Windows XP mode of Windows 7 (also on 64 bits systems).
  • Igor Petrov - 2010-12-14
    V3.4 SP2 with 64bit support is available for download 14.12.2010
  • ramafun - 2011-03-16
    Is it only about the programming system or does the rte V3.4 SP2 work on windows7 64Bit as well? Because I can't get the service started.
  • TimvH
    TimvH - 2011-03-16
    This is correct. The Control RTE doesn't work yet on 64 bits systems.
    This is scheduled for earliest 2012.
  • Russell - 2011-07-27
    Hi Team,
    Is there any further update on having the bug fixed?
    Thanks,
  • TimvH
    TimvH - 2011-08-01
    What bug?
  • Russell - 2011-08-11
    The bug that wont allow it to run on 64 bit!
  • TimvH
    TimvH - 2011-08-12
    In my opinion you can not call this a bug.
    It would be a bug if 3S-Smart Software Solutions would have created a 64bit Runtime, but it doesn't work.
    Now it is a missing feature, which is under development.
  • Russell - 2011-08-12
    Got it...The end result is that it does not work
    Good news is that it runs ok in virtual mode
  • roy.wastie - 2016-12-04
    Does it run on windows 10 64bit?
  • roy.wastie - 2016-12-05
    I only need to use the CodeSYS OPC server on windows 10 64bit. Does it have this in the RTE version?
