I got a problem with the communication between the codesys 2.3.9.35 and the PLC WAGO 750-880, a screen appears:"No gateway with the given settings could be found", when I try to setup the communication parameters, I need help, I've been trying to solve this problem for several days,
this issue occure since one of the many Windows updates on some machines,
this is solved with current CODESYS 2.3 Version
2.3.9.41 or use the standalone Gateway Setup, but the better solution is to ask
the Wago-Support if it is safe to migrate to the newest Version with the wago targets.
are the communication settings correct like direct 9600, etc.
changeable with wago ethernet settings.
please have the computer and the plc almost same number like 192.168.2.201 and 192.168.2.202
Thankyou very much Edwin, I didn´t understand about the standalone gateway setup, this is a software WAGO? or Codesys?
Dear Shooter, yes the configuration is right, I think that must be something like Edwin Schwellinger is suggesting, but I can´t find the solution yet!
best regards,
Carlos Eduardo Ibáñez
e carloseduardo@koeln.com.bo e
I'm pretty sure that this will help on that problem.
I've send you a link to download it.
cheers
I would like more information on how to solve the problem
