I've tried several things, but always with errors during compiling.
in Global variables I tried:
VAR_GLOBALÂ Â TYPEframedata:Â Â Â Â STRUCTÂ Â Â Â Â Â COB_ID:DWORD;Â Â Â Â Â Â extended:BOOL;Â Â Â Â Â Â interval:TIME;Â Â Â Â Â Â data:ARRAY[1..8]OFINT;Â Â Â Â END_STRUCTÂ Â END_TYPEÂ Â Â Â TX_CAN_frame:ARRAY[0..30]OFframedata;END_VAR
Results in the following errors:
Error 3781: Global_Variables (3): 'END_VAR' or identifier expected
Error 3781: Global_Variables (9): 'END_VAR' or identifier expected
and of course the variable type is of unknown type
placing the struct before VAR_GLOBAL either after END_VAR
results in following error
Error 4024: Global_variables(2): Expecting VAR_GLOBAL before 'TYPE'
me confused. It's not an option to declare anything locally
Construct the struct under 'Data types' tab (remove old from GVL).
And declare the TX_CAN_frame in GVL in 'Resource' tab (like you did already) or
locally.
/Torbjörn
Hi!
locally.
/Torbjörn
thank you, that solved my mystery
