Conversion BYTE to ASCII String + SysLibFileStream.lib
aurelien
2008-10-27
2008-10-31
  • aurelien - 2008-10-27
    EDIT2 : Hello everydoby, I want to convert a BYTE to is corresponding ASCII string :
    example :
    a : INT ;
    b : STRING;
    a := 65; (ASCII code => A)
    I would like the string 'A' in my var b ?
    How can i do this ?
    thank you
    Hello, have you got examples using the library SysLibFileStream ?
    Does it works with every PLC (can't find the corresponding document SysLibs_Overview.pdf) (In my case Moeller/Micro Innovation PLC)?
    I've tried regarding ansi c definition but without any success
    thank you
    EDIT: On SysLibs_Overview.pdf from Moeller, they don't speak about SysLibFileStream, so I guess it doesn't work with ?
  • aurelien - 2008-10-28
    Regarding to my first question, I guess I may process like that
    ascii:ARRAY[0..255] OF STRING(1):=33(' '), '!', '"','#','$$' ,'%' ,'&' ,'Β΄','(' ,')' ,'*' ,'+' ,',' ,'-' ,'.' ,'/' ,'0' ,'1' ,'2' ,'3' ,'4' ,'5' ,'6' ,'7' ,'8' ,'9' ,':' ,';' ,'<' ,'=' ,'>' ,'?' , '@','A' ,'B' ,'C' ,'D' ,'E' ,'F' ,'G' ,'H' ,'I' ,'J' ,'K' ,'L' ,'M' ,'N' ,'O' ,'P' ,'Q' ,'R' ,'S' ,'T' ,'U' ,'V' ,'W' ,'X' ,'Y' ,'Z' ,'[','\' ,']' ,'^' ,'_' ,'`' ,'a' ,'b' ,'c' ,'d' ,'e' ,'f' ,'g' ,'h' ,'i' ,'j' ,'k' ,'l' ,'m' ,'n' ,'o' ,'p' ,'q' ,'r' ,'s' ,'t' ,'u' ,'v' ,'w' ,'x' ,'y' ,'z' ,'{' ,'|' ,'}' ,'~' ;
  • Softwerker59 - 2008-10-28
    you are right. SysLibFileStream is not supported by Moeller PLCs.
    If you have only 1 byte which holds the corresponding ASCII value you can copy it directly to the string:
    s1 : string;
    b1 : byte;
    p1 : pointer to byte;
    p1 := ADR(s1);
    if ( b1 > 32 ) then
    p1^ := b1;
    else
    p1^ := 32; ( blank )
    end_if
    p1 := p1 + 1;
    p1^ := 0; ( terminating zero )
    This is alternative to your string table which works too.
    regards
    Klaus
  • hugo - 2008-10-30
    in the open source library from oscat you can find such routines
    w www.oscat.de w
  • aurelien - 2008-10-30
    thank you for your answers
    Softwerker59, I don't understand this part :
    p1 := p1 + 1;
    (I'm not realy fond of pointers)
    hugo, thank you and great job, is there english documentation ?
  • ndzied1 - 2008-10-30
    Strings need a terminating character (0) so that the functions that use them know where the end of information contained within the string buffer is.
    By moving a zero to the location that p1 is pointing at, you are putting that terminating character where it belongs in the string.
  • aurelien - 2008-10-31
    thank you
