It is currently Mon Feb 27, 2017 5:23 am
PostPosted: Mon Oct 27, 2008 4:28 pm
EDIT2 : Hello everydoby, I want to convert a BYTE to is corresponding ASCII string :
example :
a : INT ;
b : STRING;
a := 65; (*ASCII code => A*)
I would like the string 'A' in my var b ?
How can i do this ?
thank you
Hello, have you got examples using the library SysLibFileStream ?
Does it works with every PLC (can't find the corresponding document SysLibs_Overview.pdf) (In my case Moeller/Micro Innovation PLC)?
I've tried regarding ansi c definition but without any success :(
thank you :D
EDIT: On SysLibs_Overview.pdf from Moeller, they don't speak about SysLibFileStream, so I guess it doesn't work with ?
 Post subject:
PostPosted: Tue Oct 28, 2008 2:18 pm
Regarding to my first question, I guess I may process like that
ascii:ARRAY[0..255] OF STRING(1):=33(' '), '!', '"','#','$$' ,'%' ,'&' ,'ยด','(' ,')' ,'*' ,'+' ,',' ,'-' ,'.' ,'/' ,'0' ,'1' ,'2' ,'3' ,'4' ,'5' ,'6' ,'7' ,'8' ,'9' ,':' ,';' ,'<' ,'=' ,'>' ,'?' , '@','A' ,'B' ,'C' ,'D' ,'E' ,'F' ,'G' ,'H' ,'I' ,'J' ,'K' ,'L' ,'M' ,'N' ,'O' ,'P' ,'Q' ,'R' ,'S' ,'T' ,'U' ,'V' ,'W' ,'X' ,'Y' ,'Z' ,'[','\' ,']' ,'^' ,'_' ,'`' ,'a' ,'b' ,'c' ,'d' ,'e' ,'f' ,'g' ,'h' ,'i' ,'j' ,'k' ,'l' ,'m' ,'n' ,'o' ,'p' ,'q' ,'r' ,'s' ,'t' ,'u' ,'v' ,'w' ,'x' ,'y' ,'z' ,'{' ,'|' ,'}' ,'~' ;
 Post subject:
PostPosted: Tue Oct 28, 2008 3:41 pm
you are right. SysLibFileStream is not supported by Moeller PLCs.
If you have only 1 byte which holds the corresponding ASCII value you can copy it directly to the string:
s1 : string;
b1 : byte;
p1 : pointer to byte;
p1 := ADR(s1);
if ( b1 > 32 ) then
p1^ := b1;
else
p1^ := 32; (* blank *)
end_if
p1 := p1 + 1;
p1^ := 0; (* terminating zero *)
This is alternative to your string table which works too.
regards
Klaus
 Post subject:
PostPosted: Thu Oct 30, 2008 7:59 am
in the open source library from oscat you can find such routines
www.oscat.de
freie sps bibliothek unter www.oscat.de
 Post subject:
PostPosted: Thu Oct 30, 2008 3:30 pm
thank you for your answers
Softwerker59, I don't understand this part :
p1 := p1 + 1;
(I'm not realy fond of pointers)
hugo, thank you and great job, is there english documentation ?
 Post subject:
PostPosted: Thu Oct 30, 2008 6:26 pm
Strings need a terminating character (0) so that the functions that use them know where the end of information contained within the string buffer is.
By moving a zero to the location that p1 is pointing at, you are putting that terminating character where it belongs in the string.
nOrM
nOrM = Norman Dziedzic Jr.
 Post subject:
PostPosted: Fri Oct 31, 2008 9:03 am
thank you :)
